Flow of Control Statement...
JUK
Postby JUK » Thu Aug 18, 2016 7:15 am
Dear Sirs/Madams
I'm sure that this query will be solved very quickly, as undoubtably I am doing something very simple incorrectly. Nevertheless, I can't find a solution so I am appealing to the board.
I am attempting to calculate multi-step ahead forecasts from my VAR model and then calculate the RMSEs. As I wasn't sure how to do this I am following the instructions in the following: http://forums.eviews.com/viewtopic.php?f=5&t=9442
However. Whenever I operate:
for !i=1 to 60+!i
I am told that the 'flow of control statement' has been 'executed from the command line'
Naturally, if I skip this step and move directly to:
smpl @first @first+60+!i
I am informed (correctly, of course) that !i is not defined.
I would be very grateful if someone could offer some advice as to where I am going wrong.
Best wishes
James
Re: Flow of Control Statement...
Postby startz » Thu Aug 18, 2016 7:20 am
Put your commands in a program window rather than the command line.
JUK
Postby JUK » Thu Aug 18, 2016 8:46 am
Thank you Startz.
I knew it would be a simple case of my inability to use the software!!
Got it now,
Thanks!
