Copy from workfile/databank to workfile
radmirer
Postby radmirer » Thu Aug 11, 2016 3:23 am
Dear Team,
I want to create a new series(annual) out of specific data-points from other series(monthly).
So I do this in a while loop:
%year = @str(!year)
%yearm = @str(!year) + "M02"
series d_IPC_ann_02(!ind) = @elem(ipcn_forecast_errors::ipc_ann_{%yearm}, {%year}M12)
But when I do this, I get strange numbers which I can't find in any of my files.
Further:
series a1
series a1(1) = @elem(ipcn_forecast_errors::ipc_ann_2009m02, "2009m12")
This command gives also a wrong number, ie. not the number that is in ipc_ann_2009m02 at postion 2009m12. ( I can create the same wrong number in both commands if I specify %year)
and strangely this does not work at all (syntax error):
scalar a1 = @elem(ipcn_forecast_errors::ipc_ann_2009m02, "2009m12")
I tried both "stream" the data from a workfile and from a database, nothing worked. Thing is in another project these things worked well.
Edit: I found out that these strange numbers are averages over the hole year. So the question is how to transfer data from an monthly workfile to an annual workfile.
Re: Copy from workfile/databank to workfile
Postby EViews Gareth » Thu Aug 11, 2016 7:44 am
You'll have to control the frequency conversion by creating a link in your workfile to the data in the database, then use the @elem on that linked series.
