ARMA and explosive process
maxchen
Postby maxchen » Thu Jul 21, 2016 5:36 pm
EV 9 32bit build 2016-06-29
for an explosive process, EV9 seems not able to find the true coefficient.
!T = 200 '400 will more explosive wfcreate u !T rndseed(type=mt) 12347 genr e = 0.6*nrnd genr u = 0 genr u2 = 0 genr u3 = 0 smpl @first+1 @last u = 0.4*u(-1)+e 'U(1)=0, starting from unconditional mean u2 = 1.04*u2(-1) +e 'explosive u3 = 1.04*u3(-1) -e 'explosive, u3 = -u2 ! equation eq01.ls u ar(1) if @vernum>=9 then equation eq02.ls(arma=cls) u2 ar(1) 'produce EV8 results in EV9; discard arma=cls in EV8 else equation eq02.ls u2 ar(1) endif equation eq029.ls u2 ar(1) 'ml, ar1<1 equation eq029o.ls(optmethod=opg) u2 ar(1) show eq02 show eq029 if @vernum>=9 then show eq02.resids show eq029.resids endif
you will see that EV9 use ML to estimate ARMA model, from eq029.resids, the residuals are not normal.
My question: does EV9 restrict the AR(1) coef to <=1 in estimation?
Re: ARMA and explosive process
Postby EViews Gareth » Thu Jul 21, 2016 5:37 pm
No
maxchen
Postby maxchen » Thu Jul 21, 2016 7:01 pm
for this data set, NLS seems better than ML
c(1) = 1.04 c(2) = 0.6 equation eq02u.ls(armastart=user,showopts) u2 ar(1)
even given the true value as starting value, eq02u estimates the same values as eq029
Postby EViews Gareth » Thu Jul 21, 2016 8:32 pm
You should use nls on it then
