Data input: READ, IMPORT
shuchang
Postby shuchang » Tue Jul 19, 2016 1:09 am
Hi Gareth,
I am a long term Eviews user, but new to Eviews 9. I have great problems inputting data into a wf, and the READ I am so familiar with doesn't work now. I got empty series (no data, no heading) when using the commands:
read(b2, t=xls, sheet=total) volume_boe_eviews.xls 1
read(b2, t=xls, sheet=ndf) volume_boe_eviews.xls 8
read(b2, t=xls, sheet=df) volume_boe_eviews.xls 8
read(b2, t=xls, sheet=spot) volume_boe_eviews.xls 8
read(b2, t=xls, sheet=swap) volume_boe_eviews.xls 8
Please advise what to do. Also what would be the IMPORT command for doing this?
Best,
Chang
(95 KiB) Downloaded 594 times
test.wf1
(7.98 KiB) Downloaded 351 times
Re: Data input: READ, IMPORT
Postby EViews Gareth » Tue Jul 19, 2016 6:29 am
import volume_boe_eviews.xls range="total"
shuchang
Postby shuchang » Tue Jul 19, 2016 6:36 am
I tried the import command. I got the message: 'incomplete date spec (no start date)'
Postby EViews Steve » Tue Jul 19, 2016 8:24 am
If you manually drag the spreadsheet onto EViews, and use our Import wizard to perform the import, it will generate an IMPORT command in the capture window for you to use in your programs with all the proper settings.
shuchang
Postby shuchang » Wed Jul 20, 2016 12:21 am
Thanks.
Do you recommend to use IMPORT rather than READ now? The READ command I was so familiar with doesn't work now.
chang
Postby EViews Gareth » Wed Jul 20, 2016 6:21 am
We stopped supporting READ in EViews 4.
Postby EViews Steve » Wed Jul 20, 2016 7:46 am
As an aside, maybe we should start warning our users when they use deprecated commands in their programs. Not sure where we would show that though -- maybe the program log window (if there is one).
shuchang
Postby shuchang » Wed Jul 20, 2016 8:01 am
This might be useful indeed. For example, I always used READ as the main input method and didn't realise that it's outdated until this time it failed to work.
Many thanks.
Best,
Chang
