Using filters in @uifiledlg
JRMeyer
Postby JRMeyer » Mon Jul 18, 2016 7:14 am
I am using @uifiledlg to select an Excel worksheet as an input to my program. All seems to work as advertised with the exception of the Filter argument. I would like for the dialogue box to display only those files with an "xlsx" extension, but all files in the directory are displayed. I would note that using the filter "prg" does successfully list only those files with the .prg extension, so I guess the function is working properly within that narrow field. Am I doing something wrong, or does the filter only apply to .prg files?
Re: Using filters in @uifiledlg
Postby EViews Gareth » Mon Jul 18, 2016 8:15 am
The filter only supports "wf", "prg" or "db". The documentation should make this clearer, sorry.
JRMeyer
Postby JRMeyer » Mon Jul 18, 2016 8:20 am
OK--thanks. I guess you may consider this as a suggestion for future versions.
Postby EViews Gareth » Mon Jul 18, 2016 9:37 am
There's actually two types of filter going on. The one we currently support is basically "what type of thing am I opening/saving?" where the answer is workfile (i.e. a dataset including Excel, Stata, CSV, etc...), a database or a program.
Withing the workfile setting there is a secondary filter which allows you to specify the exact file type.
I've just added an option to the function which will go out in the next patch that allows you to, crudely, select which file type will be selected by default. It is just an integer value passed in as a string.
For example, to open a file-open dialog preselected to Excel:
=@uifiledlg("", "wf", "open", "8")
adrian_d
Postby adrian_d » Tue Aug 02, 2016 4:07 am
Hi, it is quite a serious change for me that you added this fourth parameter as obligatory. Please update the Programming Reference as soon as possible, because there is no information about what values should be entered.
Postby EViews Gareth » Tue Aug 02, 2016 4:42 am
Yep, that 4th shouldn't have been compulsory. We will fix (to make optional).
