I am using Eviews 9.
I would like to edit manually program the size of the individual graphs contained in a merged graph object.
Eviews by default makes them all equally sized.
I have been able to alter individual graph sizes by using the menu driven commands:
by selecting each graph individually, selecting Graph Options, Frame & Size, Size and Indents and changing the Frame Size .
The resulting graph exported to png is cool.png, the starting point for my menu driven changes was equitydouble.png
Is there any programming command to change these frame parameters?
Thanks in advance,
giovanni
programming graphs
programming graphs
- What I would like to be able to program
- cool.png (69.21 KiB) Viewed 3329 times
- the result of using merging graphs and align(2,1,1)
- equitydouble.png (16.39 KiB) Viewed 3329 times
Re: programming graphs
You have to change each graphs' size prior to merging them into a big one.
Thanks it worked,
I used the command graphname.options size(w,h)
before merging and it worked fine!
best regards
giobbe
best regards
giobbe
