White test
White test
Postby startz » Thu Nov 12, 2009 4:59 pm
With the attached workfile, estimate
ls cost c n
Then View/Residual tests/Heteroskedasticity test... White, hit Ok.
Error message: "Insufficient number of coefficients to test."
Bug, no?
schools from Dougherty.wf1
(13.46 KiB) Downloaded 392 times
Re: White test
Postby EViews Gareth » Fri Nov 13, 2009 11:21 am
Recently introduced bug, will be fixed in next patch for 6 (and 7).
In the mean time you can use the command:
equation eq01.ls cost c n eq01.hettest(c) @white
ihlasnobatovich
Re: White test
Postby ihlasnobatovich » Thu Jun 30, 2016 1:45 am
Hi Gareth,
I use the newest version of Eview 9, I estimate Panel GMM models with random-effects, and when I apply Hausman test, it shows an error of "Insufficient number of common coefficients to test". How to deal with it?
Please, see my attached workfile, there is an "random_cross" equation in it that I use to apply Hausman test.
Many thanks,
nkpc gmm.wf1
Eviews File
(451.95 KiB) Downloaded 296 times
basse
Re: White test
Postby basse » Wed Jul 27, 2016 8:41 am
Hi Gareth,
I seem to have the same problem as ihlasnobatovich, except that I am estimating an LS model and not GMM. Would really appreciate it if you could help me.
I have attached my file.
Kind regards,
Basse
ff3.wf1
(133.34 KiB) Downloaded 282 times
Re: White test
Postby startz » Wed Jul 27, 2016 8:59 am
Gareth's life will be easier if you tell him what the equation is :wink:
