Set convert property reseting to EViews default on copy
econmiller
Postby econmiller » Wed Nov 04, 2009 6:55 pm
Here's an unexpected one, and I'm not sure what I'm doing wrong. I have quarterly data in a worksheet where all series have a set conversion methode from high to low. I create an annual page in the same workfile and copy the data using the following commands
pagecreate(page=awork) a 1990 {%PA_SOLVTO}
copy work\* awork\
When I look at the conversion property of my series, they have all reverted to EViews default. This behavior also occurs with another routine that uses the following statements. Here, the first line is moving quarterly data to another quarterly page, while the second is moving from quarterly to annual. However the series lose their conversion properties in both the outq and outa pages.
copy work\{%sname} outq\{%sname} 'conversion method already set
copy work\{%sname} outa\{%sname} 'conversion method already set
However, if I mouse click and save a series in the work page (has correct set conversion property) and mouse click past into any of the other pages (regardless of frequency), the set conversion property commutes with the data.
Any thoughts? Thank you for considering this issue.
econmiller
Re: Set convert property reseting to EViews default on copy
Postby econmiller » Wed Dec 09, 2009 6:57 pm
Any response?
Postby EViews Gareth » Wed Dec 09, 2009 8:59 pm
Sorry, must have missed this post the first time around. I'll look into it...
Postby EViews Gareth » Fri Dec 11, 2009 9:31 am
Try grabbing the latest EViews 6 patch.
