problem with converting quarterly data to monthly data
purlenn
Postby purlenn » Thu Jun 16, 2016 1:14 am
Hi, I need to convert quarterly GDP data to monthly GDP data, I know how it is done http://forums.eviews.com/viewtopic.php?f=7&t=3799 as described in the link, I tried again and again, I bouht this program but I cant get the values... when I did, it seems as if it converted the data to monthly but infact it doesn't, because it shows the same value for 3 months as in the quarter value. I mean, when I did it by using the program, if the quarterly GDP fata for 2015Q1 is 138, it gives the same value for the 1st 2nd and 3rd months, "138". My result workpage is attached below. It must be something diffrent as 120 for the 1st month, 150 for the 2nd month etc.. (as described in the link http://forums.eviews.com/viewtopic.php?f=7&t=3799 ) Can anyone please help me... I need that data :cry:
gdp result ready.WF1
(19.95 KiB) Downloaded 531 times
Re: problem with converting quarterly data to monthly data
Postby EViews Gareth » Thu Jun 16, 2016 1:47 am
Repeating the quarterly value for each month in the quarter is a valid frequency conversion method. If you want to use a different conversion method, change the method on the paste special box
purlenn
Postby purlenn » Thu Jun 16, 2016 2:12 am
Thank you. :oops:
