Heteroskedasticity Test
DannyB
Postby DannyB » Fri Jun 10, 2016 6:41 am
I 'd like to do an heteroskedasticity test on a trend , I can retrieve the r2 of the equation with .@r2 but I can not recover the r2 of heteroskedasticity test. It would seem that we should go through a table but I wonder if there is another solution for going through a table is risky because if the number of lines changes my program will not be able to recover the right value...
Thanking you
Re: Heteroskedasticity Test
Postby EViews Gareth » Fri Jun 10, 2016 6:47 am
The only way would be to do perform the auxilliary regression yourself rather than use the built in test.
DannyB
Postby DannyB » Fri Jun 10, 2016 6:52 am
And for exemple if i want the correl of my arma test... The only way is only to freeze into table to retrieve the Prob column?
Postby EViews Gareth » Fri Jun 10, 2016 6:58 am
Right.
DannyB
Postby DannyB » Fri Jun 10, 2016 7:09 am
Ok, thanks
