Questions regarding options in FIML and solveopt
bareab87
Postby bareab87 » Fri Jun 03, 2016 3:53 am
Hi all,
Sorry if I've misplaced this question.
I have a program written by someone else, that I am trying to adjust to my data and estimations. I've had some trouble and therefore need to make sure I understand every bit of the code. I've been trying to look in the user manual and at eviews.com/help for answers, but these options are not described there?
The first question is regarding the code for estimating a system by FIML:
sysname.FIML(deriv=n)
What does the option deriv=n stand for?
The second issue is regarding setting options for model solutions:
name.solveopt(..., R=1000)
Here, I can't figure out what the R option is for? I am using Eviews 9, but the code may be written for an earlier version.
Thank you in advance.
Re: Questions regarding options in FIML and solveopt
Postby EViews Gareth » Fri Jun 03, 2016 4:00 am
Both are old, outdated commands that are no longer supported/documented (but still work).
deriv=n is use numerical derivatives.
r=1000 is perform 1,000 stochastic iterations.
bareab87
Postby bareab87 » Mon Jun 06, 2016 2:06 am
Thank you, that helps a lot!
bareab87
Postby bareab87 » Thu Jun 09, 2016 3:09 am
I have a follow-up question to this, after reading in the manual about "Solving the model" (http://www.eviews.com/help/helpintro.ht ... el.html%23).
What is the difference between M (Maximum number of iterations for solution) and R (number of stochastic iterations to perform)? The user manual describes "The Repetitions box, in the top left corner of the dialog, allows you to set the number of repetitions that will be performed during the stochastic simulation" - I guess this is R? Can M also be set in the dialog?
Postby EViews Gareth » Thu Jun 09, 2016 3:12 am
Yes, on the last tab.
M controls the numerical optimization engine.
bareab87
Postby bareab87 » Thu Jun 09, 2016 3:34 am
Could you please elaborate a little bit...? :) The default is 5000, when should I consider changing this number?
Postby EViews Gareth » Thu Jun 09, 2016 4:42 am
Explaining the details of numerical optimization methods is a little beyond the scope of a simple forum reply :D, but I am sure a Google search can provide you with lots of information.
Users browsing this forum: JMviews and 1 guest
