script for Johansen cointegration test
Posted: Mon May 02, 2016 9:18 am
by eviews1
I am looking for a script(code) to automate Johansen cointegration test in Eviews 9 COM Automation.
I was running it using Eviews menu but now I need to run the test with several sub-samples.
Thank you.
Argyn
Re: script for Johansen cointegration test
Posted: Mon May 02, 2016 9:25 am
Easiest thing to do is to run it via the menus, then use the Command Capture window to view the command line equivalent.
Posted: Mon May 02, 2016 9:32 am
by eviews1
Thank you very much for your help.
