Sign restricted VECM
Hello, I am rather new in EViews and would be very grateful for your help. I would like to ask you if there is any possibility to use the SrVAR add-in in VECM? I would like to use sign restrictions in my SVAR but face cointegration issues. Thank you!
Re: Sign restricted VECM
Cointegration is not problem for the srvar addin if you use variable in levels. Do you have the reference for sign restriction with VECM?
I mean there is an error correction equation that needs to be taken into account, that I believe is not in SrVAR add-in
I understand your point. But if you estimate VAR in levels it will implicitly take account your error correction term. I am not fan of cointegration.
Where could I see the code used in SrVAR add-in?
