A noob question
Kavorka
A noob question
Postby Kavorka » Wed Apr 13, 2016 6:03 pm
Dear all,
This is of course a noob question (which I should solve but I did not get why I did not get it right...). Thus, please submit a "for loop" link when UNDATED (according to EViews) but in fact QUARTERLY data is aggregated to ANNUAL data (so it needs to be summarized for 4 quarters in order to provide one annual observation).
For certain reasons, and since this is a simulation example that I want to show to my students, I want to use UNDATED data (and not dated quarterly to annual data which is very easily converted to annual data). E.g. for a data set like this: wfcreate undatedfile u 1000
In summary, I just want to have a frequency conversion from quarterly to annual data (for a data set where I in EViews have defined the data as undated). Please provide a SYNTAX for this tranfer.
Best regards
/P
Re: A noob question
Postby EViews Gareth » Wed Apr 13, 2016 8:33 pm
Sorry, I don't understand the question.
Kavorka
Re: A noob question
Postby Kavorka » Thu Apr 14, 2016 3:50 am
I add an excel example of what I mean.
Basically I want to make a frequency conversion from quarterly to annual data with syntax, but where the data is undated like this
I hope this explains what I ask for.
/P
Example of frequency conversion.xlsx
Example of a frequency conversion.xlsx
(10.8 KiB) Downloaded 585 times
Re: A noob question
Postby EViews Gareth » Thu Apr 14, 2016 6:30 am
You can use the general match merge copy interface, using the date series on each page as the id series.
Kavorka
Re: A noob question
Postby Kavorka » Thu Apr 14, 2016 12:26 pm
Thanks for the answer but I do not want to use the interface (if I understand this correctly you refer to this interface http://www.eviews.com/Learning/freqconv_a.html e.g. at slide number 14). This is what I would like to do but not by this interface - instead solely by using syntax, since I will do it over and over again. /P
Re: A noob question
Postby EViews Gareth » Thu Apr 14, 2016 12:29 pm
Use the copy command then.
Kavorka
Re: A noob question
Postby Kavorka » Thu Apr 14, 2016 4:07 pm
I thought that I could do this using the EViews interface, and then save "Display Command Capture Window" and then use this syntax later (since I am only interested in the syntax).
In the
I could only find examples for dated time-series data, not for undated data.
It works easily when I have dated data, but when I have this undated series (see the attachment where I generated 10000 quarterly integers in the Quarterly tab, and tries to convert this to 2500 Annual data observations based on e.g. the first quarter every year) - it does not work for me.
In the Quarterly page I copy the x variable.
I go to the Annual page
Right-click at the white area and chooses "Paste Special..."
Could you please help me with the following steps in order to convert the frequency from quarterly to annual data for x (still keeping the file undated without converting the entire file to a time-series file)? (I use EViews 9.5)
temp.wf1
An example file
(205.83 KiB) Downloaded 475 times
Re: A noob question
Postby EViews Gareth » Thu Apr 14, 2016 7:15 pm
You need to have series containing dates.
