Matrix inverse problem
trubador
Did you use forum search?
Postby trubador » Fri Apr 08, 2016 6:50 am
I couldn't figure out why there is such a big difference in the results:
importmat(name=xmat) C:\Users\...\Desktop\xmat.xlsx matrix ymat = xmat*@inverse(@inner(xmat))*@transpose(xmat) xopen(m) xput xmat xrun "zmat=xmat*inv(xmat'*xmat)*xmat';" xget zmat matrix difmat = ymat-zmat scalar difsum = @sum(difmat) show difsum
xmat.xlsx
Data matrix
(74.28 KiB) Downloaded 503 times
Re: Matrix inverse problem
Postby EViews Gareth » Fri Apr 08, 2016 8:34 am
Not sure, but I just did it in R and R matches the EViews results (I think).
Postby EViews Gareth » Fri Apr 08, 2016 10:28 am
Further, since you're taking a projection matrix, the following should result in a matrix of approximately zero (I think):
matrix test1 = xmat.@t*(@identity(467)-ymat) matrix test2 = xmat.@t*(@identity(467)-zmat)
