Why does
cause(4) y x
work, but not
equation eq1.cause(4) y x
I get the error message "Equation does not have estimates" when I click at "eq1"
I would like to save the result (with a loop), so therefore I am interesting in saving in equation eq1 (which I will put in {!i} with a loop. I could of course use OLS manually and test using a e.g. an F-test, and save it, but I would like to utilize the canned routines for e.g. AIC etc.
Syntax for the Granger causality test
Re: Syntax for the Granger causality test
I've spent some time trying to figure out what you're trying to do, but I have failed.
Granger causality works on two series objects (or, more properly, a group object). It has nothing to go with equations objects.
I don't know what you're trying to achieve by trying to estimate an equation object using the Granger causality test. Granger causality is not an estimation method. It is a test.
