make shaded graph for forecasting
Posted: Wed Mar 09, 2016 12:45 pm
by ch2324
Hi everybody,
how can make shaded graph for forecasting like this picture.
Re: make shaded graph for forecasting
Posted: Wed Mar 09, 2016 12:48 pm
This is a fan chart.
The EViews blog will have a post on creating fan charts soon!
Posted: Wed Mar 09, 2016 12:51 pm
by ch2324
great! :D thanks! Mr Gareth.
Posted: Thu Apr 28, 2016 8:18 am
by ch2324
First of all, i would to think EViews team for all their efforts to make this Add-in 8) ;
i have data frequency weekly named gas, so i want to make fanchart for my data the problem i use the Add-in but can give me a result, and i have use the program in the blog to make mode, skewness and uncertainty. but i get error mesage: Error in Sample: MODE is not defined in "SMPL IF MODE<>NA".
could you just explain in few line the steps for this.
Best CHERIF.
Posted: Thu Apr 28, 2016 9:43 am
Slight bug in the add-in, it will be fixed.
Posted: Thu Apr 28, 2016 10:01 am
It has been updated.
Posted: Thu Apr 28, 2016 11:03 am
by ch2324
ok, but i have no idea what is the problem i can't get mode, skewness and uncertainty series, or in first create it in the workfile, and next use the Add-in.
(*)the prg calcquant i use it in the first to generate mode, skewness and uncertainty.
could you exmplain please i have no idea to use this Add-in :(
Posted: Thu Apr 28, 2016 11:06 am
I'm not sure what there is to explain. In order to calculate a Bank of England style fan chart, you need to have the mode, uncertainty and skewness values of your forecast.
The add-in does not calculate those for you, it uses them as inputs.
Posted: Thu Apr 28, 2016 12:40 pm
by ch2324
i understand now, so the calcquant prg are the way to make mode, skewness and uncertainty.
thanks for you help :)
Posted: Fri Sep 30, 2016 10:12 pm
by tvonbrasch
Hi Gareth,
how do i use the fanchart addin using program code?
i tried
cpi.fan mode uncertainty skewness
but then the option menu came up?
can you also give the precise link to where BoE explains the skewness and uncertainty series?
Posted: Mon Oct 03, 2016 7:34 am
There is no command line interface to this add-in. You're better off stealing the source code and adding it to your own program to suit your needs.
This paper (although not a BoE paper) explains the methodology well:
http://www.banrep.gov.co/docum/ftp/borra468.pdf
