READ command
tchaithonov
READ command
Postby tchaithonov » Wed Sep 16, 2009 9:26 am
Hi All,
I am writing a program that reads csv files into eviews, but I have 2 problems that I've encountered.
1. I tried to generalized file name and variable names, so say I use %file_name and %var_name as this read command is within several for loops. The %file_name part works but %var_name does not. Eviews claims that it's a "illegal or reserved name".
This is the command I use for inserting a specific variable (with header in the csv's) into a wf:
read(c2, t=csv, name, d=c) %file_name %variable_name
2. If I change the command to read in multiple variables within a csv, Eviews is not cooperating with a scalar variable in the place of a number in the statement
read(c2, t=csv, name, d=c) %file_name !columns
Besides, putting "C2" as the starting point of the dataset doesn't seem to eliminate the columns that I don't want. In this case, I don't want it to read the first 2 columsn and start with C2. Does this thing only work if the incoming file is a xls? If that's the case, is there a workaround?
Thanks guys!
Tchaithonov
Re: READ command
Postby EViews Gareth » Wed Sep 16, 2009 9:47 am
The first issue is because you don't have braces around the variable name. Try
read(c2, t=csv, name, d=c) %file_name {%variable_name}
I can't replicate the second issue - using a command variable works fine for me.
Entering "C2" won't work on a CSV file. You could try using the skipcol and skiprow options though.
Also, if you're using EViews 7 at all, you could try the new import command rather than the read command.
