storing alpha/intercept/constant
lous
Postby lous » Mon Sep 14, 2009 10:37 am
I need to store the intercept/constant for many (!) (CAPM-like) OLS regressions in a table/text.
How should I program such thing...? I have no experience with programming so please answer in ‘dummy-language :D ’
Thanks a lot!
Re: storing alpha/intercept/constant
Postby EViews Gareth » Mon Sep 14, 2009 10:43 am
You can retrieve any coefficient from an equation by using the @coef data member. Assuming you have the constant as the first coefficient in your regression, you would use equation_name.@coef(1) where equation_name is the name of your regression. You can then store that into a table. Something like:
table mytable mytable(1,1) = myequation.@coef(1)
which would put the intercept from myequation into the first row, first column of a table called mytable
lous
Postby lous » Tue Sep 15, 2009 3:10 am
Thanks so much!
With your help I also found out to make it a loop and store every alpha (500) below eachother :) Many thanks for your quick response...
