@wfindnc - bug?
Posted: Thu Dec 17, 2015 2:47 am
try and run the following code where you open the attached workfile:
close @all
%dir=@runpath
cd %dir'"C:\tvb\articles\labour_services\eviews"
wfopen wfindnc
for !i=570 to 571
%eq=kvartstroll.@line(!i)
if @isobject("test")=1 then
delete test
endif
model test
test.append {%eq}
'generate text file with equations where endogenous variable has already been defined
text problemequations
'TRY TO UNCOMMENT THE FOLLOWING LINE:
scalar a_{!i}_=@wfindnc(kvarts.@endoglist,@trim(test.@endoglist))
if @wfindnc(kvarts.@endoglist,@trim(test.@endoglist)) = 0 then
kvarts.append {%eq}
else
problemequations.append {%eq}
problemequations.append {!i}
endif
This creates a blank textfile problemequations. However, if you comment out the scalar a_{!i}_.... line and rerun the program, the textfile problemequations is filled with some text, for some reason. Do you understand what is causing this?
THomas
close @all
%dir=@runpath
wfopen wfindnc
for !i=570 to 571
delete test
endif
model test
test.append {%eq}
kvarts.append {%eq}
else
endif
THomas
