Testin for insignificant variables
Ynwe
Postby Ynwe » Fri Dec 11, 2015 2:45 am
hello I have the following outputs
I have a problem: My first result is on the left. To test the three insigfnificant variables I should use a redundant variable test right? It tells me though to remove all 3! But I know from just reducing the model by hand, that life expectancy should be significant
What am I doing wrong?
trubador
Did you use forum search?
Re: Testin for insignificant variables
Postby trubador » Fri Dec 11, 2015 5:12 am
You are misinterpreting the test result. Read the null hypothesis carefully and then decide whether or not to reject it using the p-value of related test statistic.
Ynwe
Postby Ynwe » Fri Dec 11, 2015 5:38 am
Thank you, I confused H0 and HA
