I have a few questions:
1: the values, educ religion and urban are values between 0 and 1, life expec between 70-80ish and the GDP between 10k and 50k. Divorce rate is between 1-3
Do I need to change my variables around a bit since they all are such different numbers, or will it only effect my interpretation of my values?
2: Sadly, the urbanisation percentage doesn't seem to exert any influence on the divorce rate in my country, even though the literature on divorces suggest so. Could I try anyting to see if I could get anyting out of it
3: I have only done a simple OLS so far. Is there anything else I could do hat would show some cool results? This is a small homework, but only doing OLS is a bit too simple. I wanted to do a different module, but the lector said that would be too time consuming so I had to fall back to this. Would like to do just a bit more to spice it up a bit :)
edit: is it an issue that my constant is negative 35?
