objects not found in database
LMGZ
Postby LMGZ » Thu Nov 26, 2015 1:37 pm
Hello:
I created an Eviews database from a workfile and, later on, deleted a few objects in the database directly. Now if I fetch all the objects from that database to a workfile, it tells me the deleted objects were not found. How do I fix this error, the objects are not there for a reason.
Thanks in advance
LMGZ
Re: objects not found in database
Postby EViews Gareth » Thu Nov 26, 2015 1:53 pm
I'm not sure I follow. You're saying that you deliberately deleted an object from a database, then you try to fetch that object, and EViews tells you it isn't there? That's what is supposed to happen.
LMGZ
Postby LMGZ » Thu Nov 26, 2015 3:25 pm
to clarify:
I run the following code on the database.
fetch(d=T) *
Then an error message pops up saying that it cannot find the objects I deleted. I don't want the objects to be in the database that is why I deleted them, however the fetch function is still looking for them. That is the problem I have.
Postby EViews Jason » Mon Nov 30, 2015 9:58 am
We will take a look at it and post back
Postby EViews Jason » Tue Dec 01, 2015 9:51 am
We can't replicate the error.
Is your copy of EViews up to date? Select help->EViews Update to verify.
LMGZ
Postby LMGZ » Tue Dec 01, 2015 6:22 pm
hello.
I can't do that because it's blocked by the admin. However I checked "about Eviews" and it says I am running the Jun 8 2015 build Eviews 9 64-bit. Does that help?
Postby EViews Gareth » Tue Dec 01, 2015 8:35 pm
You'll need to update your copy. You can download the update manually from our website:
http://www.eviews.com/download/download.html
But you will need admin rights to install.
