Interpolate if gap is not larger than 3 obs
strypste
Postby strypste » Thu Nov 19, 2015 9:53 am
Dear All
I want to interpolate a series but it can only interpolate if the number of missing observation is 3 or smaller.
So for example if I have a series like this:
14.6301
NA
NA
16.969
NA
NA
NA
NA
NA
18.4762
20.5717
then the command should interpolate the first gap but not the second gap.
Any ideas?
Best
s
Re: Interpolate if gap is not larger than 3 obs
Postby EViews Gareth » Thu Nov 19, 2015 10:29 am
There's nothing built in that will do it. You'll have to write a program.
Luckily I found an ancient program that I wrote that performs simple linear interpolation on up to 2 missing values in a row. Should be fairly straight forward to add an additional 3rd.
create u 100 rndseed 1 series y=nrnd smpl if nrnd>0.8 y = na smpl @all series temp=y 'interpolation of two missings smpl if y = na and y(1) = na temp = (y(-1) + y(2))/3 smpl if y=na and y(-1) = na temp = (y(-2)+y(1))*2/3 'interpolation of a single missing smpl if y = na and temp=na temp = (y(-1)+y(+1))/2 smpl @all show temp y
strypste
Postby strypste » Thu Nov 19, 2015 10:38 am
Thanks for providing the program.
Cheers
strypste
Postby strypste » Thu Nov 19, 2015 11:34 am
I think there was a small error in the code related to the interpolation of two gaps... The following code produces exactly the same as the ipolate command.
create u 100 rndseed 1 series y=nrnd smpl if nrnd>0.8 y = na smpl @all series temp=y ' Interpolate y with the built in command (so this will also fill gaps larger than 2) y.ipolate y_i 'interpolation of two missings ' first missing smpl if y = na and y(1) = na temp = (2*y(-1) + y(2))/3 ' This is slightly different compared to previous code ' second missing smpl if y=na and y(-1) = na temp = (y(-2)+2*y(1))/3 ' This is slightly different compared to previous code 'interpolation of a single missing smpl if y = na and temp=na temp = (y(-1)+y(+1))/2 smpl @all show temp y y_i
