How to display and save the etable in autoarma
joad
Postby joad » Mon Nov 09, 2015 8:42 am
How do you display and save the etable that is generated in the autoarma procedure? The only series I manage to save in the workfile is the final forecast, test_f below...
Many thanks in advance.
test.autoarma(maxsar=1, maxsma=1, forclen=3, etable, fgraph) test_f
Re: How to display and save the etable in autoarma
Postby EViews Gareth » Mon Nov 09, 2015 9:00 am
If you want to freeze the table into its own table, then something like:
freeze(myspool) test.autoarma(maxsar=1, maxsma=1, forclen=3, etable, fgraph) test_f myspool.extract(mytable) eqoutput
If you want an actual equation object, use the eqname= option.
