Programming a table matrix
YK_Econ
Postby YK_Econ » Tue Nov 03, 2015 3:51 am
Hi everybody,
I do panel estimations. I have 4x8 (=NxK) different estimations. 4 different dependent variables times 8 different regressions.
I want to create a matrix table(table1), where I present the main findings.
table1(1,K) = coefficient of LOG(WS(-1)) / (coefficient LOG(consumption) * (-1))
so the long-run relationship in an ECM model between WS and consumption. What I want to program now, is that this result is in the first row in 8 different columns.
second row is investment (same procedure)
third row (which i might have troubles with as well) is the sum of the first two rows.
that is what i got so far:
matrix(8,5) table1 for !i = 1 to 8 for !h = 1 to 3 table1(!h,!i) = {i}.@coef(!h) next next
and it doesnt work (and i am not surprised by that)
best
YK
Re: Programming a table matrix
Postby EViews Gareth » Tue Nov 03, 2015 9:10 am
You need to reference the names of the equations when using .@coef. What are your equation names?
YK_Econ
Postby YK_Econ » Tue Nov 03, 2015 10:53 am
i came so far by now:
matrix(4,5) check for !n = 1 to 2 for !h = 2 to 10 check(1,!n) = c{!n}.@coef(!h) next next
and now it puts the 10th coef into the matrix (however i want the sum of coefs 2 to 10)
my equation names are c1, c2 ... , c8, i1, ... , i8, ci1,...,ci8, y1,...,y8
btw. this is just my simplified try program, i still want to get what i wanted to get initially.
many thanks
YK
Postby EViews Gareth » Tue Nov 03, 2015 11:10 am
check(1,!n) = @sum(c{!n}.@coefs) - c{!n}.@coef(!)
YK_Econ
Postby YK_Econ » Tue Nov 03, 2015 11:23 am
check(1,!n) = @sum(c{!n}.@coefs) - c{!n}.@coef(!h)
'whole loop:
matrix(4,5) check
for !n = 1 to 2
for !h = 2 to 10
tried this, but gives me wrong values. I can't figure out which value it calculated. I want to obtain the sum of the 2nd to the 10th coef.
thanks
best
YK
Postby EViews Gareth » Tue Nov 03, 2015 11:31 am
I took the sum of all the coefficients, then minused the first coefficient. I was assuming you had only 10.
YK_Econ
Postby YK_Econ » Tue Nov 03, 2015 11:39 am
sorry. i should be more explicit.
i have 30 coefs. i want the sum of the 2nd to the 10th.
at the end of the day, i want the sum of coef 2 to 10 divided by 1-(sum of coefs 11 to 18)
and coef 3 divided by coef 5 * (-1) * scalar inv_gdp * scalar one_ws (for example: (coefx3/(coefx4*(-1)))*scalar inv_gdp * scalar one_ws )
thanks
best
Postby EViews Gareth » Tue Nov 03, 2015 11:41 am
Just do the addition manually. coef(2)+coef(3)...
YK_Econ
Postby YK_Econ » Tue Nov 03, 2015 11:57 am
isnt there a way to make a loop?
because in the end it is a 5x8 matrix. 40 times typing this is a pain.
thx
Postby EViews Gareth » Tue Nov 03, 2015 12:28 pm
Yes, you could loop through them.
