groups in a panel
mariposa
groups in a panel
Postby mariposa » Fri Aug 28, 2009 1:39 am
Dear all,
for my current project I want to analyze groups of countries. As on the time series level I have much too less observations for the estimations I want to make (f.ex. rolling estimations of 5 year windows with annual data), I want to structure my workfile as a panel (by the way I have 50 countries, 27 years).
Now I am interested in analyzing different subgroups of the countries (my cross-section-identifiers). I am aware of that this is not the idea of a panel - but still, that is what I want to do :wink:
A pool probably would be easier, but as far as I read the forum, with 50 countries it is better to use a panel.
One idea is to make several pages with different panel (containing different subsets of countries), but I hope, that there is a more elegant way to change the composition of cross-section-identifieres in my panel!!
Can anybody help me with this??
Best regards, Mariposa
Re: groups in a panel
Postby EViews Gareth » Fri Aug 28, 2009 7:16 am
Just put everything in one page, then whenever you want to do something, just set the sample to be only the cross-sections you want.
mariposa
Postby mariposa » Fri Aug 28, 2009 8:24 am
Thanks, Gareth! I already left my office, where I have my EViews-Version, so I can only try on Monday... Actually, it is the first time I use a panel workfile structure. So I guess the programming code to set the sample is similar to the time series case: sth. like
smpl _usa _deu _fra
? But I will have a look at the Reference Manual Monday.
Thanks again and have a nice weekend :)
(I know in the US you have still some hours to work...)
Postby EViews Gareth » Fri Aug 28, 2009 8:50 am
no, something like:
smpl if crossid = "_usa" or crossid = "_deu" or crossid = "_fra"
mariposa
Postby mariposa » Fri Aug 28, 2009 8:55 am
mariposa
Postby mariposa » Tue Sep 01, 2009 7:07 am
Hi again,
I tried it, but unfortunately it does not work (so in the meantime I worked with a pool, but I think I would be really better off with a panel structured workfile). Can you give me a hint?!
I tried it also with the workfile of one of your posts (http://forums.eviews.com/viewtopic.php?f=7&t=74#p168 ):
http://www.eviews.com/Forum_support/poo ... poolg7.wf1, that I changed to a panel structure with:
pagestack unemp?
Now, with the suggested
smpl if crossid = "_can" or crossid = "_fra"
I get the error message "Error in Sample: CROSSID is not defined" :( ; thus as I think that the crosssection identifiers are stored in id01, I tried
smpl if id01 = "_can" or id01 = "_fra"
But then I get the message "WARNING: Sample contains no observations." :?
What do I do wrong? What is the correct way to define the sample?
Postby EViews Gareth » Tue Sep 01, 2009 8:09 am
It's case sensitive. In that particular example, it should be:
smpl if id01 = "_CAN" or id01 = "_FRA"
mariposa
Postby mariposa » Tue Sep 01, 2009 8:12 am
oh great! thank's a lot! :D
mariposa
can a string variable contain quotes within quotes?
Postby mariposa » Wed Sep 02, 2009 1:39 am
Hi again,
as I want to make rolling estimations for different "subgroups" within my panel, I want to programm a loop. Therefore my string variable should support quotes within quotes (with some "hierarchical order"), what it apparently does not do. Is there any solution??
Here comes a summary of what I want to do:
%kl1=" id01="_BRA" or id01="_CHN" or id01="_CZE" " %kl2=" id01="_BEL" or id01="_DNK" or id01="_FIN" or id01="_FRA" " for %condition {%kl1} {%kl2} ' set window size !window = 5 ' get size of workfile !length = @obsrange ' compute stats for each window for !i = 1 to !length-!window+1 smpl @first+!i-1 @first+!i+!window-2 if {%condition} 'now the estimations etc. next 'refering to condition
The problem is in the first part, where I define the conditions. As the part of if id01="..." already contains quotes I did not find out how to sum it up. :(
Postby EViews Gareth » Wed Sep 02, 2009 8:08 am
Make a sample object first, then use that sample object inside the loop. Something like:
sample smpl1 if id01="_BRA" or id01="_CHN" or id01="_CZE" sample smpl2 if id01="_BEL" or id01="_DNK" or id01="_FIN" or id01="_FRA" for %condition smpl1 smpl2 smpl @first+!i-1 @first+!i+!window-2 if {%condition}
mariposa
Postby mariposa » Wed Sep 02, 2009 8:41 am
Great, it works! Many thanks, Gareth!!
I think, I already said it several times, but as it is true, once again: I really appreciate the reliable help in this forum!! :D Without your aid, I suppose that I already would have despaired several times of my EViews programms :wink:
acsbarnabas
Postby acsbarnabas » Wed Nov 25, 2009 2:48 pm
Dear All,
I am a first time user here, so I just hope that my query finds the right person. I have a panel database with 500 cross sections. I have 60 variables I would like to create a correlation matrix on each cross section. However I do not want to create the correlation matrix 500 times by making a sample for each cross section. Do you have an idea how I could create 500 correlation matrices for the 500 cross sections in one or a few step?
I am really grateful for your reply,
brgds,
Barnabas
Postby startz » Wed Nov 25, 2009 5:26 pm
You're talking about 500 tables, each with about 1800 unique entries. That's close to a million numbers you want to generate. Out of curiousity, what are you going to do with a million numbers when you get them?
acsbarnabas
Postby acsbarnabas » Thu Nov 26, 2009 2:09 am
Hi Startz:)
No, it is in one table, ordered in a Panel structure, if it makes the difference.;) Actually I am examining the relationship between stock and macro fundamentals, and by generating the correlation tables, I would like to spot high correlation "areas", which I could model later on.
In relation to this. Do I have to set sg, in order to run regression on panel data?
Thank you.
brgds,
Barni
