Exporting GARCH condiitonal variance terms
ulysse
Postby ulysse » Wed Aug 26, 2009 10:16 am
I am currently trying to develop a rolling GARCH program for my thesis. The forum has been helpful for the structure, however i am still trying to find out how i can export the coefficients of the conditional variance in a table after each roll.
scalar noobs=2870
scalar nw=200
matrix(noobs-nw,1) results
for !i=nw to noobs
smpl !i-nw !i
equation garch_n
garch_n.ARCH(1,1) dtsx60 @ tsx60vol
The results should be exported at this point into a table, but how???
!i=!i+50
I would also like to know wether it is correct or not to introduce volume as an endogenous variable in the conditional variance with @tsx60vol...
Thank you very much for your help!
Ulysse
trubador
Did you use forum search?
Re: Exporting GARCH condiitonal variance terms
Postby trubador » Thu Aug 27, 2009 10:51 am
You should first decide which parameters will be saved. Constructing a table is very easy in EViews. As an example, the following command will generate a 5x2 table and will name it as results:
table(5,2) results
The following code, on the other hand, will label the first column and then assign the related coefficient values to the second column:
for !i=1 to 5 results(!i,1) = "coef" + @str(!i) results(!i,2) = garch_n.@coefs(!i) next
ulysse
Postby ulysse » Fri Aug 28, 2009 10:35 am
Hello Trubador,
Thank you very much for your answer, this was just what i needed. Now i just need to introduce the standard errors in the table for each coeficient, do you know which command brings that to the table?
Thanks again for your answer!
Ulysse
trubador
Postby trubador » Fri Aug 28, 2009 1:46 pm
garch_n.@stderrs(!i)
