Slider bar ignores sample if conditions
trubador
Did you use forum search?
Postby trubador » Mon Aug 17, 2015 3:39 am
I am not sure if this is the intended behaviour, but please change the sample via slider bar in the following examples:
'Panel setting wfopen .\grunfeld_baltagi_panel.wf1 smpl @all if fn=4 f.line(panel=stack) 'Undated cross section wfcreate u 100 series x=nrnd series y = nrnd smpl @all if x>0 y.line
trubador
Re: Slider bar ignores sample if conditions
Postby trubador » Tue Aug 25, 2015 2:41 am
The latest patch does not seem to address this issue. So, shall I safely assume that this is the intended behaviour?
Postby EViews Gareth » Tue Aug 25, 2015 6:21 am
Yes, the slider bar ignores if conditions, by design.
