replacing text in a string
jbonanca
Postby jbonanca » Mon Aug 10, 2015 12:30 pm
Could someone help me understand why I'm failing at this?
I have a string with these contents:
_GDP_STUFF_158
_GDP_STUFF_20
_CPI_STUFF_120
_CPI_STUFF_1
I'd like to make a new string consisting only of two elements: "_GDP_STUFF_" and "_CPI_STUFF_". My strategy was to use @wreplace to replace the numbers with nonsense that I would then use @wdrop to get rid of, and then use @wunique to get me only unique elements.
If anyone has a more elegant way they've done something similar, please let me know. But outside of that, I am failing trying to get @wreplace to work.
Assuming the name of mu string is "stringname," I am trying things like:
string stringname=@wreplace(stringname,"_*_*_*","_*_*_00")
to no avail.
Anyone have any guidance? Thank you!
Re: replacing text in a string
Postby EViews Gareth » Mon Aug 10, 2015 1:06 pm
You can't replace a wildcard with something.
In your examples, I think something like:
create u 10 string stringname = "_gdp_stuff_158" string stringname1 = @left(stringname, @instr(stringname, "_", 3)) + "00" show stringname1
should work
jbonanca
Postby jbonanca » Mon Aug 10, 2015 1:33 pm
thank you
jbonanca
Postby jbonanca » Mon Aug 10, 2015 1:47 pm
Forgive me Gareth but I just realized it won't work. I posed my problem incorrectly; apologies.
My starting string is this: "_GDP_OLDSTUFF_18 _GDP_OLDSTUFF_122 _GDP_NEWSTUFF_50"
and the output i need is this string:
"_GDP_OLDSTUFF_ _GDP_NEWSTUFF_"
so what i need is just way to drop the numbers and retain every unique element once I ignore the numbers.
if I use your approach i get
"_GDP_OLDSTUFF_00" -- so I lose "_GDP_NEWSTUFF_"
sorry to follow up on it, but this is surprisingly vexing. if you have any other ideas i would be very grateful!
Postby EViews Gareth » Mon Aug 10, 2015 1:55 pm
Loop through the words of your string using my replacement on each word one at a time.
jbonanca
Postby jbonanca » Mon Aug 10, 2015 2:10 pm
haha. oh boy. it is clearly miller time ... thanks gareth... got a little stuck there! :)
