ccc garch model
maxchen
ccc garch model
Postby maxchen » Wed Jul 29, 2015 8:21 am
'EV9 20150723 x86
pageload dsdf.txt system bg bg.append df = c(1) bg.append ds = c(2) bg.arch(showopts) @ccc c arch(1) garch(1) ' GARCH1 = C(3) + C(4)*RESID1(-1)^2 + C(5)*GARCH1(-1) ' GARCH2 = C(6) + C(7)*RESID2(-1)^2 + C(8)*GARCH2(-1) ' COV1_2 = C(9)*@SQRT(GARCH1*GARCH2) equation eqf.arch df c equation eqs.arch ds c
data file http://forums.eviews.com/download/file.php?id=3371
note that in the first part of the output of bg.arch, the following parts come up twice
Estimation settings: tol=0.00010, derivs=analytic
Initial Values: C(1)=9.35833, C(2)=9.22667, C(3)=171.118,
and questions
1 Is there any way to restrict the coefs in the individual variance equation to be positive? in this example, C(5) and C(8) are negative, such that the forecast variance GARCH2 is negative.
2 the coefs of eqf and eqs, are far away from those in GARCH1 and GARCH2
maxchen
Re: ccc garch model
Postby maxchen » Fri Jul 31, 2015 12:11 am
EV 9 ver 20150728 x86
another bug: p726, Chapter 1. Object Reference
General Options: b Use Berndt-Hall-Hall-Hausman (BHHH) as maximization algorithm. The default is Marquardt.
now the new options should be "optmethod=opg"
It seems that these is updated in equation object, but not in system object yet.
