Page 1 of 2
ETS, the smooth series
Posted: Thu Jul 09, 2015 7:49 am
by maxchen
EViews 9, ver 20150701, 32bit on XP
!T = 60 '# of obs in estimation %otb1 = "1/20/2012" %otc = "2/22/2012" wfopen J2012-1m2.wf1 delete cocs smpl %otb1-!T+1 %otb1 freeze(mode=overwrite, oosp) coc.ets(e=e, t=e, modsel=hq, forc=%otc, table=cl, graph=cl, noconv) cocs
data file http://forums.eviews.com/download/file.php?id=3416
bugs and questions
1 option forc: OR (EViews 9 Object Ref.pdf) p550, forc=arg Specify the date of the forecast end point. If omitted, the end point will be the end of the workfile sample. Note that in p551, forc=num Set the length of the out-of-sample forecast. By default the forecast will be until the end of the workfile range.
2 the value in cocs does not match any column in Forecast Comparison Table of oosp. However, in EV 9 ver 20150624, cocs match the column of (M,AD,N), which does not converge
Question: for irregular data, how to do with "seasonal specification"
Re: ETS, the smooth series
Posted: Thu Jul 09, 2015 8:32 am
1) Noted, will fix.
2) Can't replicate - when I run your program, the values i COCS are a constant value of 0.008859, which matches the numbers give in the table for ANN.
The seasonal components of ETS probably doesn't work with irregular data.
Posted: Thu Jul 09, 2015 5:40 pm
by maxchen
in my computer, the COCS are NOT a constant value of 0.008859
can not attach file larger than 2M, so the screen capture video, go see https://youtu.be/1lGNZ1u_C30
and the screenshot
screenshot
Screenshot from 2015-07-10 082924.png (66.36 KiB) Viewed 12536 times
Posted: Fri Jul 10, 2015 8:48 am
Posted: Fri Jul 10, 2015 9:00 pm
by maxchen
I try
1 patch EViews9Patch_070115.exe again
2 reboot
try many times, the same results as my video, not your video, sigh
Posted: Sun Jul 12, 2015 5:11 pm
by maxchen
Is it possible the reason that I am running in VirtualBox?
I setup a virtual machine of win 7 this weekend, and the result still the same as my previous screenshot.
Posted: Thu Jul 16, 2015 8:39 am
Try putting the noconv option first.
Posted: Thu Jul 16, 2015 5:23 pm
by maxchen
nothing change, sigh.
Posted: Thu Jul 16, 2015 5:28 pm
Try today's patch
Posted: Sat Jul 18, 2015 7:00 am
by maxchen
unchanged, attached.
Screenshot from 2015-07-18 214525b.PNG (103.27 KiB) Viewed 12328 times
Posted: Sat Jul 18, 2015 10:33 am
Could you try copying and pasting the code you put in the first post in this thread into a new EViews program, without going via any other package?
Posted: Mon Jul 20, 2015 6:39 am
by maxchen
I did those way every time.
I record just now: https://youtu.be/eNLSY1RUneU
first VM: win 7, brand new install, only EViews 9 (the notepad++ is green, copy into only, no need to setup)
the second VM: XP
Posted: Mon Jul 20, 2015 8:21 am
How did you get the programs into EViews?
Posted: Mon Jul 20, 2015 6:21 pm
by maxchen
yeah, I do copy and paste from post 1.
noconv comes first
Screenshot from 2015-07-21 091846.png (75.08 KiB) Viewed 12227 times
noconv comes last
Screenshot from 2015-07-21 091521.png (81.41 KiB) Viewed 12227 times
Posted: Tue Jul 21, 2015 12:16 am
Under Options->General Options->Estimation Options, what are your settings?
