Reduce white border in graph
johansamuelsson
Contact:
Postby johansamuelsson » Fri Jul 03, 2015 10:02 pm
When creating emf-files (or other file-formats) from graphs there is an unnecessarily large white border around the graphs, see the first graph. There would be nice if the emf-files instead look like the second graph.
Therefore, is it possible to include some "cropping"-command when saving graphs or is it possibly to change standard to "no white border" (or minimum white border)?
Regards Johan
wfcreate(a) annual 2000 2015 Series a1 Series a2 a1.adjust = 1 .. 10 a2.adjust = 1 .. 20 Series a3 = @Pc(a1) Series a4 = @Pc(a2) Group g a* Freeze(tmp) g.mixed line(a1) line(a2) bar(a3) bar(a4) tmp.setelem(3) axis(r) tmp.setelem(4) Axis(r) tmp.axis overlap tmp.save(t=emf, u=cm, w=6, h=4, -trans) c:\temp\tmp
Re: Reduce white border in graph
Postby EViews Jason » Tue Jul 07, 2015 2:50 pm
It isn't possible right now but we will add to our list of things to investigate.
johansamuelsson
Contact:
Postby johansamuelsson » Sat Jul 11, 2015 12:56 am
Great
Regards Johan
Postby EViews Jason » Fri Feb 05, 2016 9:46 am
As a followup. There will be a new setting in the options->Graph defaults dialog under Exporting to enable/disable padding in the next release.
