F-Stat becomes <10, after controls added
Posted: Thu Jul 02, 2015 7:37 pm
by Apple Tan
This question has been posted here: http://stats.stackexchange.com/question ... rols-added
I am using Eviews 7.
Model A:
Y = c + log(X) + A
Using a GMM IV, instrument = A_lag. F-stat > 10
Model B:
Y = c + log(X) + A + B
Using a GMM IV, instrument = A_lag. F-stat < 10
So why is it that after B is included my F-stat < 10? This means my instrument becomes weak after B is included. What does this imply? Is A_lag and B correlated?
Thank you
Re: F-Stat becomes <10, after controls added
Posted: Thu Jul 02, 2015 8:32 pm
You seem to have more variables than instruments. Something doesn't make sense.
Posted: Thu Jul 02, 2015 11:40 pm
by Apple Tan
A_lag is the instrument in the true sense of the word, that is the instrument for the endogenous variable.
Of course, all the right-hand side variables in the 2nd stage are included in the 1st stage as instruments too.
Thank you
Posted: Fri Jul 03, 2015 9:11 am
You might want to post your EViews workfile, including the two equations you are estimating.
Posted: Sat Jul 04, 2015 7:39 pm
by Apple Tan
M data is confidential so I am only posting my estimation equation and results (with the coefficients value removed).
Hope you can help
Thank you
Posted: Sat Jul 04, 2015 7:40 pm
by Apple Tan
Model 2 is here
Posted: Sun Jul 05, 2015 7:32 am
That is a surprising outcome. I do not see why you should see that large a change.
At the same time, doing GMM with 21 observations is pretty questionable. GMM is a large sample estimator.
Posted: Sun Jul 05, 2015 5:14 pm
by Apple Tan
Thanks for the reply. Then should I use TSLS instead of GMM?
Thank you
Posted: Sun Jul 05, 2015 5:22 pm
by Apple Tan
i tried with TSLS.
My F-stat stll become <10 in Model 2.
Can anyone explain why this is happening?
Thank you
