F-Stat becomes <10, after controls added
Apple Tan
Postby Apple Tan » Thu Jul 02, 2015 7:37 pm
This question has been posted here: http://stats.stackexchange.com/question ... rols-added
I am using Eviews 7.
Model A:
Y = c + log(X) + A
Using a GMM IV, instrument = A_lag. F-stat > 10
Model B:
Y = c + log(X) + A + B
Using a GMM IV, instrument = A_lag. F-stat < 10
So why is it that after B is included my F-stat < 10? This means my instrument becomes weak after B is included. What does this imply? Is A_lag and B correlated?
Thank you
Re: F-Stat becomes <10, after controls added
Postby startz » Thu Jul 02, 2015 8:32 pm
You seem to have more variables than instruments. Something doesn't make sense.
Apple Tan
Postby Apple Tan » Thu Jul 02, 2015 11:40 pm
A_lag is the instrument in the true sense of the word, that is the instrument for the endogenous variable.
Of course, all the right-hand side variables in the 2nd stage are included in the 1st stage as instruments too.
Thank you
Postby startz » Fri Jul 03, 2015 9:11 am
You might want to post your EViews workfile, including the two equations you are estimating.
Apple Tan
Postby Apple Tan » Sat Jul 04, 2015 7:39 pm
M data is confidential so I am only posting my estimation equation and results (with the coefficients value removed).
Hope you can help
Thank you
Model1 Results.jpg (159.91 KiB) Viewed 7834 times
Model 1.jpg (76.21 KiB) Viewed 7834 times
Apple Tan
Postby Apple Tan » Sat Jul 04, 2015 7:40 pm
Model 2 is here
Postby startz » Sun Jul 05, 2015 7:32 am
That is a surprising outcome. I do not see why you should see that large a change.
At the same time, doing GMM with 21 observations is pretty questionable. GMM is a large sample estimator.
Apple Tan
Postby Apple Tan » Sun Jul 05, 2015 5:14 pm
Thanks for the reply. Then should I use TSLS instead of GMM?
Thank you
Apple Tan
Postby Apple Tan » Sun Jul 05, 2015 5:22 pm
i tried with TSLS.
My F-stat stll become <10 in Model 2.
Can anyone explain why this is happening?
Thank you
