Granger Causality Result in Eviews
Kalec
Postby Kalec » Mon Aug 17, 2009 11:52 am
I have done Granger causality test in Eviews, but I don't know how to interpret the result. I checked the User Guide with no luck.
I was thinking to check critical value for the F-test? but I cannot find the values.
If I am on the right track, can anyone please let me know how I can obtain the critical values ?
Please help.
Here are my results:
ScreenHunter_08 Aug. 17 19.46.jpg (40.82 KiB) Viewed 45676 times
ScreenHunter_09 Aug. 17 19.53.jpg (40.44 KiB) Viewed 45678 times
Thanks again
Kalec
theologos
Re: Granger Causality Result in Eviews
Postby theologos » Mon Aug 17, 2009 12:11 pm
Read carefully the manual and you will find the answer! Try to think if the critical values are of interest whenever the p-values are reported. The p-value does the job.
Kalec
Postby Kalec » Mon Aug 17, 2009 1:05 pm
Thanks theologos
In the guide, I can see an example on Granger- causality and it does indicate whether to reject the H0, but it does not give reason for that. (unless I am reading the wrong part?)
ScreenHunter_10 Aug. 17 20.54.jpg (54.79 KiB) Viewed 45659 times
In relation to the probability, does it mean that whenever there is a probability figure in the result, it could be relied on?
So, rejection for probability < 0.05 for 95% confident level?
Thanks again
Kalec
theologos
Postby theologos » Tue Aug 18, 2009 2:14 am
Yes correct. We fail to reject the null hypothesis whenever the p-value is greater than the 0.05 (given that this is the selected level of significance).
Regards
Kalec
Postby Kalec » Tue Aug 18, 2009 6:35 am
Thanks so much theologos
Kalec
ekta1
Postby ekta1 » Sun Oct 28, 2012 11:26 am
Hello Sir/Madam,
Please, the Pairwise Granger test does not ask for the order of integration of the data to be specified. Is the order of integration of the data part of the computation done by the test or not?
Thank you,
Emml.
Postby EViews Gareth » Sun Oct 28, 2012 12:41 pm
No.
ekta1
Postby ekta1 » Mon Oct 29, 2012 6:48 am
So does it mean the order of integration of the data is not necessary in a Pairwise Granger test? Some empirical models requires the specification of both lag order (k) and order of integration (d) for test of causality, example Seabra and Flach (2005:2).
Why the difference?
Thanks, Emml.
ekta1
Postby ekta1 » Fri Nov 02, 2012 12:26 pm
Please if the p-value is more than 5% but the F-statistic exceeds the F-critical value, should the null be accepted or rejected?
thanks.
joshimrunal
Postby joshimrunal » Sun Feb 01, 2015 1:10 pm
Thank you for your kind cooperation
