Dear Ladies and Gentlmen,
I am trying to estimate a dynamic panel model using the dynamic panel wizard from eviews.
When I try to estimate the model I receive the message "Insufficient number of observations"
Could you please help me.
The file is attached below
Thanks in advance
Marcelo Cabus Klotzle
Problem with estimation of dynamic panel model
Re: Problem with estimation of dynamic panel model
You have insufficient observations. Either estimate a different model, or get more observations.
Can someone help me with estimation using an unbalanced panel. I am not sure if the years for which certain cross sections do not have corresponding data should be reported as blank/NA/simply removed from the list?
ALso, in my EVIEWs version, the option of GMM/Dynamic Panel is simply not appearing. It only shows GMM. Is there something wrong with what I am seeing or the package that I have downloaded?
Are you sure you have a panel eorkfile?
Yes I have a pool workfile so it should show right?
No. Dpd is only available for panels, not pools.
