Adding a counter to write options?
Posted: Thu Jun 04, 2015 3:00 pm
by elac
Hello everyone, I need help with this code i've been working on.
cd "C:\Users\xxx\Desktop\GARCH_xxx"
wfopen 200
%r1="200"
%r2="480"
for !i=1 to 94
PAGESELECT {%r{!i}}
'mode quiet
smpl @all
smpl 3 1804
equation garch11.ARCH(DERIV=AA) FLUOPNET_{%r{!i}} C TIME SF_D SF_S SF_M D_Q1 D_Q2 FLUOPNET_{%r{!i}}(-1)
garch11.forecast(f=na e) fluopnet_{%r{!i}}_pf
garch11.makegarch var_{%r{!i}}_1p
genr vol_{%r{!i}}=var_{%r{!i}}_1p^.5
plot vol_{%r{!i}}
freeze (vol_{%r{!i}})
group gru_{%r{!i}} vol_{%r{!i}} var_{%r{!i}}_1p
'fluopnet_{%r{!i}}_pf
write(A2, t=xls) "C:\Users\xxx\Desktop\GARCH_xxx\vol_g.xls" gru_{%r{!i}}
So this program exports 94 times 2 series to an Excel spreadsheet, but right now it just overwrites the same cell (A2) until the last iteration. How do I fix this so after each iteration the program pastes the series on the next cell C2, E2, G2 and so on?
Thanks in advance.
Re: Adding a counter to write options?
Posted: Thu Jun 04, 2015 3:05 pm
Use wfsave rather than write. There is a range= argument that lets you specify the Excel range to save to.
Posted: Fri Jun 05, 2015 9:46 am
by elac
Ok, so I came up with this:
' Set parameters
%start = "1"
%end = "20"
wfopen 200
%r1="200"
%r2="480"
for !i=1 to 2
PAGESELECT {%r{!i}}
mode quiet
smpl @all
smpl 3 1804
'plot vol_{%r{!i}}
' Export data to Excel
group gru_{%r{!i}} vol_{%r{!i}} var_{%r{!i}}_1p fluopnet_{%r{!i}}_pf
%range ="!A1"+%i
wfsave(type=excel,mode=update) "C:\Users\xxx\Desktop\GARCH_xxx\vol_g.xls" range=%range @smpl %start %end @keep gru_{%r{!i}} vol_{%r{!i}} var_{%r{!i}}_1p fluopnet_{%r{!i}}_pf
'write(A2, t=xls) "C:\Users\emiliolopez\Desktop\GARCH_falabella\vol_g.xls" gru_{%r{!i}}
It doesn't look like the counter on the range argument is working because the Excel spreadsheet only shows data for the last iteration, what could the problem be? Thanks.
Posted: Fri Jun 05, 2015 10:02 am
I don't see anywhere where you have defined what %i is
Posted: Fri Jun 05, 2015 11:03 am
by elac
You are right, I think I got it this time.
%range = !i+"!a1"
I've been reading this post
http://forums.eviews.com/viewtopic.php?f=3&t=11553 and it's been really helpful, but I'm getting the scalar added to string error unlike Ral and I can't see why.
Posted: Fri Jun 05, 2015 11:21 am
!i is a number. You're trying to add it to a string, which you can't do. You need to convert the number into a string.
Try:
Although I'm not sure how that will become a valid Excel range. I guess what you actually want to do is increase the column by 3 each time.
I would do something like:
!j = !i*3-2
%range = "!" + @chr(!j+96) + "1"
a(!i,1) = %range
