Adding a counter to write options?
elac
Postby elac » Thu Jun 04, 2015 3:00 pm
Hello everyone, I need help with this code i've been working on.
cd "C:\Users\xxx\Desktop\GARCH_xxx" wfopen 200 %r1="200" %r2="480" for !i=1 to 94 PAGESELECT {%r{!i}} 'mode quiet smpl @all smpl 3 1804 equation garch11.ARCH(DERIV=AA) FLUOPNET_{%r{!i}} C TIME SF_D SF_S SF_M D_Q1 D_Q2 FLUOPNET_{%r{!i}}(-1) garch11.forecast(f=na e) fluopnet_{%r{!i}}_pf garch11.makegarch var_{%r{!i}}_1p genr vol_{%r{!i}}=var_{%r{!i}}_1p^.5 plot vol_{%r{!i}} freeze (vol_{%r{!i}}) group gru_{%r{!i}} vol_{%r{!i}} var_{%r{!i}}_1p 'fluopnet_{%r{!i}}_pf write(A2, t=xls) "C:\Users\xxx\Desktop\GARCH_xxx\vol_g.xls" gru_{%r{!i}} next
So this program exports 94 times 2 series to an Excel spreadsheet, but right now it just overwrites the same cell (A2) until the last iteration. How do I fix this so after each iteration the program pastes the series on the next cell C2, E2, G2 and so on?
Thanks in advance.
Re: Adding a counter to write options?
Postby EViews Gareth » Thu Jun 04, 2015 3:05 pm
Use wfsave rather than write. There is a range= argument that lets you specify the Excel range to save to.
elac
Postby elac » Fri Jun 05, 2015 9:46 am
Ok, so I came up with this:
cd "C:\Users\xxx\Desktop\GARCH_xxx" ' Set parameters %start = "1" %end = "20" wfopen 200 %r1="200" %r2="480" for !i=1 to 2 PAGESELECT {%r{!i}} mode quiet smpl @all smpl 3 1804 equation garch11.ARCH(DERIV=AA) FLUOPNET_{%r{!i}} C TIME SF_D SF_S SF_M D_Q1 D_Q2 FLUOPNET_{%r{!i}}(-1) garch11.forecast(f=na e) fluopnet_{%r{!i}}_pf garch11.makegarch var_{%r{!i}}_1p genr vol_{%r{!i}}=var_{%r{!i}}_1p^.5 'plot vol_{%r{!i}} freeze (vol_{%r{!i}}) ' Export data to Excel group gru_{%r{!i}} vol_{%r{!i}} var_{%r{!i}}_1p fluopnet_{%r{!i}}_pf %range ="!A1"+%i wfsave(type=excel,mode=update) "C:\Users\xxx\Desktop\GARCH_xxx\vol_g.xls" range=%range @smpl %start %end @keep gru_{%r{!i}} vol_{%r{!i}} var_{%r{!i}}_1p fluopnet_{%r{!i}}_pf 'write(A2, t=xls) "C:\Users\emiliolopez\Desktop\GARCH_falabella\vol_g.xls" gru_{%r{!i}} next
It doesn't look like the counter on the range argument is working because the Excel spreadsheet only shows data for the last iteration, what could the problem be? Thanks.
Postby EViews Gareth » Fri Jun 05, 2015 10:02 am
I don't see anywhere where you have defined what %i is
elac
Postby elac » Fri Jun 05, 2015 11:03 am
You are right, I think I got it this time.
' Export data to Excel group gru_{%r{!i}} vol_{%r{!i}} var_{%r{!i}}_1p fluopnet_{%r{!i}}_pf %range = !i+"!a1" wfsave(type=excel,mode=update) "C:\Users\xxx\Desktop\GARCH_xxx\vol_g.xls" range=%range @smpl %start %end @keep gru_{%r{!i}} vol_{%r{!i}} var_{%r{!i}}_1p fluopnet_{%r{!i}}_pf
I've been reading this post http://forums.eviews.com/viewtopic.php?f=3&t=11553 and it's been really helpful, but I'm getting the scalar added to string error unlike Ral and I can't see why.
Postby EViews Gareth » Fri Jun 05, 2015 11:21 am
!i is a number. You're trying to add it to a string, which you can't do. You need to convert the number into a string.
Try:
%range = @str(!i) + "!a1"
Although I'm not sure how that will become a valid Excel range. I guess what you actually want to do is increase the column by 3 each time.
I would do something like:
!j = !i*3-2 %range = "!" + @chr(!j+96) + "1" a(!i,1) = %range
