Case-switch
EconMike
Case-switch
Postby EconMike » Mon May 04, 2015 10:24 am
Hi there,
Just wondering what would be the easiest way to implement something akin to a switch-case statement in EViews. Is there some sort of dictionary or map function, or are nested if-statements the best option as in the code below?
Thanks in advance,
Michael
for %ind CN RL AU
if %ind="CN" then
%naics = "23"
else
if %ind="RL" then
%naics = "53"
else
if %ind="AU" then
%naics = "71"
endif
endif
endif
Re: Case-switch
Postby EViews Gareth » Mon May 04, 2015 10:27 am
Nested ifs :(
EconMike
Re: Case-switch
Postby EconMike » Mon May 04, 2015 10:31 am
:( indeed. It could get pretty ugly.
Thanks anyway.
Re: Case-switch
Postby EViews Glenn » Mon May 04, 2015 11:28 am
You can fake a dictionary using something like
%list1 = "cn rl au gb fc" svector a = @wsplit(%list1) %list2 = "23 53 71 53 94" svector b = @wsplit(%list2) for %z cn rl au for !i=1 to @rows(a) if (%z = a(!i)) then %naics = b(!i) %temp = %z + ": " + %naics statusline %temp break endif next next
Here I'm using %temp to show the paired strings at the bottom of the screen.
If you need to do this a lot, I'd make a subroutine for the inner matching loop and pass in the comparison and lookup vectors. Then you'd have something like
%list1 = "cn rl au gb fc" svector a = @wsplit(%list1) %list2 = "23 53 71 53 94" svector b = @wsplit(%list2) for %z cn rl au call lookup(%naics, a, b) next
where the subroutine lookup is defined appropriately.
EconMike
Re: Case-switch
Postby EconMike » Mon May 04, 2015 12:30 pm
Thanks for that Glenn. This should do the trick, and the subroutine makes it far cleaner.
Cheers,
Michael
