How to do nonparametric regression in Eviews 9?
timbod2003
Postby timbod2003 » Tue Apr 28, 2015 12:50 pm
If I want to do nonparametric regression in Eviews, say Local Constant Least Squares or Local Linear Least Squares, with different types of kernels and bandwidth selection, how would I go about doing this? I have searched through the Eviews guide and cannot find anything regarding this.
Re: How to do nonparametric regression in Eviews 9?
Postby EViews Gareth » Tue Apr 28, 2015 12:56 pm
EViews doesn't really offer nonparametric regression, other than for drawing fit lines on scatter plots.
timbod2003
Postby timbod2003 » Tue Apr 28, 2015 1:00 pm
Ok thanks. Is this something that is in consideration for future releases?
timbod2003
Postby timbod2003 » Wed Apr 29, 2015 8:48 am
Gareth,
When we fit the line to a scatter plot, is there anyway via coding or commands to store the value of the line or equation 13.6 (from Eveiws 9 guide) and/or calculate derivatives at specific points?
Postby EViews Gareth » Wed Apr 29, 2015 8:58 am
Nope.
timbod2003
Postby timbod2003 » Wed Apr 29, 2015 9:04 am
ok thanks
Postby EViews Glenn » Wed Apr 29, 2015 4:45 pm
Not quite true. You can save the fitted points from the nonparametric fit using Proc/Make Distribution Plot Data... from the group object menu, and use these data to calculate things like derivatives as desired. For the command form, look at the group proc distdata.
Postby EViews Gareth » Wed Apr 29, 2015 5:22 pm
Good point
