Pagesave - problem in Eviews 9
johansamuelsson
Contact:
Postby johansamuelsson » Fri Apr 24, 2015 11:10 pm
I get error when I sometimes use PageSave in Eviews9 (but works in Eviews8). It seems to have and to do with the series names and/or the length of the seriesname. I've done two examples
Both codes below works fine in Eviews8 but running first code in Eviews9, I get the following message
' Codeexample 1 WfCreate(page=Q) Q 1980q1 2016q4 Series abcdefghijklmno = Rnd PageSave(t=Excelxml) "C:\Temp\Temp.Xlsm" Range="Sheet1!B2" Byrow @Keep abcdefghijklmno @Smpl 1980Q1 2016Q4
Runs the second code, I get another error message
' Codeexample 2 WfCreate(page=Q) Q 1980q1 2016q4 Series abcdefghijklmno1 = Rnd PageSave(t=Excelxml) "C:\Temp\Temp2.Xlsm" Range="Sheet1!B2" Byrow @Keep abcdefghijklmno1 @Smpl 1980Q1 2016Q4
Versions: Eviews8: Standard Edition - Apr 20 2015 build and Eviews9: Standard Edition - Apr 20 2015 build
Regards Johan
Re: Pagesave - problem in Eviews 9
Postby EViews Steve » Sat Apr 25, 2015 9:19 am
Thanks for the report Johan. I'll look at it Monday...
Postby EViews Steve » Mon Apr 27, 2015 10:36 am
Johan:
I think this issue was fixed by a previous bug fix because I wasn't able to reproduce the issue. We are just about to release a new 9 patch in a few moments. Please download it (when it's available) and try your test again.
johansamuelsson
Contact:
Postby johansamuelsson » Mon Apr 27, 2015 12:59 pm
Steve, works fine now! Thanks
