Non linear model estimations
jessisam
Postby jessisam » Fri Aug 07, 2009 5:08 am
Hi!
I have a data set that are non linear in the parameters. If I estimate this with LS regression, there is a way of handeling this problem by iteration. However, when I insert the regression line and take the tab "Options" , this tab is greyed out, and I cannot choose anything. Does this mean that Eviews estimates the LS regression with a non linear method or with a linear method?
How can I estimate my equation with a non linear method? I cannot transform the parameters with log because this did not work. So I need a method that accept non linear parameters.
Thanks for your help!
jessisam
Re: Non linear model estimations
Postby jessisam » Fri Aug 07, 2009 5:12 am
By the way, does quantile regression regression handle non linear parameters?
theologos
Postby theologos » Fri Aug 07, 2009 5:59 am
Please be more specific. Upload your file and state the desired specification.
Regards
Postby EViews Gareth » Fri Aug 07, 2009 8:11 am
In answer to the first question - EViews will only show the iteration options if your problem is non-linear. If it is a linear problem, those options are greyed out. Thus if you see them greyed out, it is because EViews believes your problem to be linear.
Quantile regression does not allow non-linear models (in EViews at least).
Alexandre Monteiro
Postby Alexandre Monteiro » Tue Oct 13, 2020 7:34 am
Hi, Eviews 11 handle with nonlinear quantile regression?
Postby EViews Gareth » Tue Oct 13, 2020 8:45 am
No
