Eviews Crash in data import
jackB
Postby jackB » Thu Apr 09, 2015 2:48 am
If possible, it would be good if you could look at a bug that causes eviews to crash when import data from excel programmatically.
Using a script to import data from a number of files successively, the following command causes eviews to crash on occasion. the crash only occurs when 2 or more files are being imported (i.e. it will work in a one off import).
import(type=excelxml, c=%freq) %dir range=%shtRng @id {%id}
where the %.. strings carry appropriate values from a table.
This is using Eviews 8.1 with the latest (Apr 2) build but the bug has existed in prior versions.
Let me know if you need more details.
Jack
Re: Eviews Crash in data import
Postby EViews Gareth » Thu Apr 09, 2015 4:07 am
It is probably data dependent. Could you provide the files you're importing?
