Large numbers crash Seasonal Adjustment
jpfeifer
Postby jpfeifer » Wed Apr 08, 2015 12:01 pm
Using Tramo-Seats on the attached debt data for Belgium crashes Eviews 8.1 when using Tramo-Seats. The reason seems to be that Tramo cannot handle large numbers. Dividing everything by 1E8 alleviates the problem. It would be great if Eviews could provide the associated error messages instead of simply crashing.
belgium.wf1
(9.36 KiB) Downloaded 256 times
Re: Large numbers crash Seasonal Adjustment
Postby EViews Gareth » Wed Apr 08, 2015 3:04 pm
Unfortunately since we do not write Tramo/Seats, there is little we can do to contain the errors caused by Tramo/Seats. If Tramo/Seats crashes, it does have a knock on effect that then crashes EViews.
jpfeifer
Postby jpfeifer » Thu Apr 09, 2015 8:39 am
I understand that you cannot fix the underlying problem, but crashing the program means that there is poor exception handling in Eviews. It should be possible to check whether Tramo/Seats outputs any files. If not, abort with an error message.
Postby EViews Gareth » Thu Apr 09, 2015 1:06 pm
Unfortunately Tramo is a DLL, not a completely stand alone executable. It is pretty much impossible to exception handle a DLL like Tramo.
