How To Insert a Time Trend
DogeProphet
Postby DogeProphet » Sun Mar 29, 2015 5:18 am
I am trying to insert a time trend into my model estimating the impact of HIV on GDP. I have included capital investment, gov spending HIV prevalence and Life Expectancy as independent variables. I took logs of all variables in the estimation equation so my equation is: log(gdp) c log(govspend) log(capital) log(hiv) log(life). I also estimated this equation with cross-section and panel fixed effects. However, whenever i try and insert @trend to include a time trend within my model to test for serial autocorrelation, I get near singular matrix error. I have no idea what this is and no idea on how to fix this. Please Help. I have attached my workfile and used all the adjusted data for the regression and life expectancy.
workingfile_paneldatafinal.wf1
(117.7 KiB) Downloaded 302 times
Re: How To Insert a Time Trend
Postby startz » Sun Mar 29, 2015 6:53 am
You can't have both a time trend and period fixed effects. They're redundant.
DogeProphet
Postby DogeProphet » Sun Mar 29, 2015 6:57 am
Thank You. I assume this means that sice i'm running the fixed effects I don't need to run a time trend?
Postby startz » Sun Mar 29, 2015 7:00 am
That's right.
DogeProphet
Postby DogeProphet » Sun Mar 29, 2015 7:03 am
Slightly off topic but at what confidence interval does eviews run regressions at by default? 0.95 or 0.90?
Postby startz » Sun Mar 29, 2015 7:47 am
I'm afraid the question doesn't make sense. Regressions aren't run at any confidence interval. After a regression is run, one can use the output to compute any desired confidence interval.
