Hi everybody!
I want to estimate a unobserved components model with explanatory variables.
Thereby the explanatory variables include also a lagged dependent variable y(t-1) (the remaining terms are other lagged variables of order (t-1)).
By means of the aforementioned model i want to calculate one-step-ahead out-of-sample forecasts with recursive parameter estimation.
I know i can manage a recursive forecasting scheme with time-varying parameters including in the state vector.
The usual approach is to specify a random walk specification for the parameters.
But is this viable for the parameter of the lagged dependent variable?
Literature suggests, that time-varying parameters of lagged dependent variables need some degree of continuity.
Are there specifications which are more suitable?
I thank you very much for a discussion.
Many greetings from Germany, Yohan.
Unobserved components models with lagged dependent variable
Re: Unobserved components models with lagged dependent varia
Yes, random walk specification is very flexible, which may not be appropriate for certain cases. You can also try AR(1) or smoothed spline specifications.
