Variance by month
miorinnovo
Variance by month
Is it possible to program a monthly series from a daily series where the monthly variable is the variance of the daily series?
Re: Variance by month
Put the daily data in a daily workfile page.
Create a monthly page corresponding to those dates.
Copy the daily to the monthly performing a frequency conversion which averages the data over the high-frequency observations.
For programming, use the copy command to copy between the two pages.
miorinnovo
How does the variance come into it though?
In the frequency conversion you can specify the method of going from high to low. One method is to take the variance of the high-frequency data corresponding to the lower frequency. Thus, the variance of the daily for each month is put into the corresponding month.
miorinnovo
I see frequency conversion in the properties for the series but there doesnt seem to be the variance option you mention.
'create some data and pages
wfcreate(page=mydaily) d7 1990 2000
series x=nrnd
'create monthly variance series
series monthly_variance = @varsby(x, @datefloor(@date, "MM"))
miorinnovo
Thanks!
That seems to have worked. The variance I get isn't exactly the same as when I square the standard deviation in the stats table of a series with just one month of data, not sure why.
Population/sample difference
miorinnovo
Sorry how do you mean? If I have a series and copy one month of data into a new series, the standard deviation should match up with the method you gave me for variance for that month, no?
Do you want the population variance or the sample variance? (I.e. Divide by n or n-1)
miorinnovo
Oh I follow. When I put the one month of data in its own series my denominator is 12 instead of 11. Thanks again Gareth, you're the man
