Engle Granger Cointegration Test
nicolesaba
Postby nicolesaba » Wed Mar 11, 2015 7:05 pm
I have several series on which I would like apply Engle-Granger test.
But I am having trouble saving the results as a table and then moving on to apply the same test on other series.
I tried the freeze command, but all it does is come up with an empty table.
This is what I am using:
coint(method="eg", trend="const") ser01 ser02
freeze(table1)
If I try freeze(table1) coint(method="eg", trend="const") ser01 ser02, I get an error message.
Thanks in advance.
Re: Engle Granger Cointegration Test
Postby EViews Gareth » Wed Mar 11, 2015 7:35 pm
group mygrp ser01 ser02 freeze(table1) mygrp.coint(method="eg", trend="const)
nicolesaba
Postby nicolesaba » Wed Mar 11, 2015 7:48 pm
Hi again. Thanks for the help.
I just copied and ran this code above, but I got an error message "Unmatched quotes in FREEZE......."
Do you know what it is and how can I fix it?
Thanks again!
trubador
Did you use forum search?
Postby trubador » Thu Mar 12, 2015 12:39 am
As the message indicates, there is a missing quote in Freeze command: ...,trend="const")
eisamabodian
Postby eisamabodian » Wed Mar 25, 2015 10:50 am
In the first step you must discern integration degree of the variables.
the variables should be I(1).
In the second step Run your regression, for example:
y c x1 x2 x3
in the third step you should run unit root test (ADF,PP,...)on the residuals of the regression.
Residuals should be stationary or I(0)
the other method is using SARGAN & BARGHAVA table.
run your regression and then check it's Durbin Watson value.
If your regression's DW be higher than critical values in the table,you have cointegration among variables.
