Automatic ARMA selection
Postby EViews Gareth » Wed Jul 29, 2009 12:20 pm
'Create some data. Delete these first few lines if you want to run on your existing workfile. create u 1000 series y=nrnd 'Program that calculates the "best" ARMA specification for an equation. Edit the variables below to match your particular data/setup. %eqname = "EQ01" 'name of equation object that will be used. %maxAR = "2" 'maximum number of AR terms %maxMA = "3" 'maximum number of MA terms %dep = "Y" 'dependent variable %regs = "C " 'independent variables %criterion = "@AIC" 'which criterion to use enter "@AIC" for Akaike, "@schwarz" for Schwarz, and @HQ for Hannan-Quinn !maxAR = @val(%maxAR) !maxMA = @val(%maxMA) close {%eqname} 'create table for storing critical values. %matname = "crits" if @isobject(%matname) then %matname = "__crits" if @isobject(%matname) then delete {%matname} endif endif table(!maxar+2,!maxma+2) {%matname} {%matname}(1,1) = "AR / MA" {%matname}.setlines(1) +b {%matname}.setlines(a) +r 'set sample smpl @first+!maxAR @last !mincrit = 1e12 'set the minimum to an artificially large value to begin 'estimate the models %arstring = "" for !i=0 to !maxar 'build up string for AR terms. if !i>0 then %arstring = %arstring + " ar(" + @str(!i) + ")" endif %mastring = "" for !j=0 to !maxma 'build up string for MA terms if !j>0 then %mastring = %mastring + " ma(" + @str(!j) + ")" endif 'estimate equation equation {%eqname}.ls {%dep} {%regs} {%arstring} {%mastring} 'capture criterion if @upper(%criterion) = "@AIC" then !crit = {%eqname}.@aic endif if @upper(%criterion) = "@SCHWARZ" then !crit = {%eqname}.@schwarz endif if @upper(%criterion) = "@HQ" then !crit = {%eqname}.@hq endif 'compare criterion if !crit < !mincrit then !mincrit = !crit !bestAR = !i !bestMA = !j %bestARstr = %arstring 'store the best ar string %bestMAstr = %mastring 'store the best ma string {%matname}.settextcolor(@all) black 'table formatting. !ii=!i+2 !jj=!j+2 {%matname}.settextcolor(!ii,!jj) red endif {%matname}(!i+2,!j+2) = !crit {%matname}(!i+2,1) = !i {%matname}(1,!j+2) = !j next next equation {%eqname}.ls {%dep} {%regs} {%bestARstr} {%bestMAstr} show {%eqname} show {%matname}
Re: Automatic ARMA selection
Postby EViews Gareth » Wed Jul 29, 2009 2:04 pm
Note that this program was posted as a guide as to how such a program could be written, and is in no way a recommendation of the use of such a program as a method of calculating the best ARMA structure for your data :D
In practice it seems that such AIC/BIC/HQ based selection routines tend to over-specify the ARMA terms by a fair bit.
micmic
Postby micmic » Thu Feb 18, 2010 8:59 pm
I tried it but it said
@UPPER is an illegal or reserved name in "IF @UPPER("@AIC")="@AIC" THEN
Is there an alternative word for " UPPER " I can use? Does this code work in EVIEWS 5?
micmic
Postby micmic » Mon Feb 22, 2010 12:06 pm
This code only works in EVIEWS 6.0
Postby EViews Gareth » Mon Feb 22, 2010 12:17 pm
True, although you could always change the code to remove the @upper parts. Change the line:
to be:
if %criterion = "@AIC" then
Of course you then lose the ability to specify the IC you want in lower case letters.
micmic
Postby micmic » Mon Feb 22, 2010 2:17 pm
Thanks Gareth. This is very helpful.
micmic
Postby micmic » Mon Feb 22, 2010 3:36 pm
I noticed that using this code EVIEWS 6.0 cannot handle ARMA terms greater than 11 (i.e. ARMA(11,11)). I have no trouble running ARMA(1,11) but when I increase it I get warning "Too Many ARMA Terms".
Is there a way to increase EVIEWS memory size to accomodate higher order ARMA terms?
Postby EViews Gareth » Mon Feb 22, 2010 4:27 pm
It isn't really a case of memory size. There's just a limit on how many ARMA terms we let you estimate.
kanonathena
Postby kanonathena » Wed Sep 01, 2010 11:25 am
I modified this code to regress inflation on lags of inflation (0-4 lags) and lags of indicator x (inl: long term interest rate) (1-4 lags) . Using AIC to automatically select lags, I got two tables, one is
_Crits
lags of inflation / lags of x 1.000000 2.000000 3.000000 4.000000
0.000000 3.162417 3.042816 2.999997 2.976678
1.000000 3.162417 3.042816 2.999997 2.976678
2.000000 3.162417 3.042816 2.999997 2.976678
3.000000 3.162417 3.042816 2.999997 2.976678
4.000000 3.162417 3.042816 2.999997 2.976678
Why is AIC is the same for different lags of inflation?
The other table
Crits
AR / MA 1.000000 2.000000 3.000000 4.000000
0.000000 2.995104 2.916265 2.904264 2.860316
I don't understand the reason for two tables. Can someone explain to me this part of the original code:
%matname = "crits"
delete {%matname}
endif
endif
What is @isobject? What does mat from %matname refer to?
and also this part:
%arstring = ""
for !i=0 to !maxar
if !i>0 then
endif
%mastring = ""
for !j=0 to !maxma
if !j>0 then
endif
What does %arstring and %mastring equal to when !i and !j are 0? It seems undefined from the code?
Lastly, this is modified code I used:
%maxINF= "4" 'maximum number of AR terms
%maxX = "4" 'maximum number of MA terms
%dep = "INF" 'dependent variable
%regs = "INL" 'independent variables
!maxINF = @val(%maxINF)
!maxX = @val(%maxX)
close {%eqname}
%matname = "crits"
delete {%matname}
endif
endif
table(!maxINF+2,!maxX+2) {%matname}
{%matname}(1,1) = "lags of inflation / lags of x"
!mincrit = 10000 'set the minimum to an artificially large value to begin
%infstring = ""
for !i=0 to !maxINF
if !i>0 then
%infstring = %infstring + " inf(-" + @str(!i) + ")"
endif
%xstring = ""
for !j=1 to !maxX
'build up string for indicator
if !j>1 then
%xstring = %xstring + " inl(-" + @str(!j) + ")"
endif
'estimate equation
equation {%eqname}.ls {%dep} c {%arstring} {%xstring}
'capture criterion
endif
endif
endif
'compare criterion
!mincrit = !crit
!bestINF = !i
!bestX = !j
%bestINFstr = %arstring 'store the best ar string
%bestXstr = %mastring 'store the best ma string
!ii=!i+2
!jj=!j+2
endif
equation {%eqname}.ls {%dep} c {%bestINFstr} {%bestXstr}
The best model is:
C 1.454179 0.093277 15.58990 0.0000
Only a constant term, can anyone tell me what is wrong with my code?
Postby EViews Gareth » Wed Sep 01, 2010 12:06 pm
Seems a lot of your questions could be answered by reading through the manual. I'll have a go at some of them though.
%matname = "crits"
delete {%matname}
endif
endif
The individual questions I'll leave up to the manual to describe. However all that code is doing is making sure that if there is already an item called CRITS, then we don't use that name, rather we use the name __CRITS.
%arstring = ""
for !i=0 to !maxar
if !i>0 then
endif
%mastring = ""
for !j=0 to !maxma
if !j>0 then
endif
Both strings are initialised as "" (i.e. empty strings).
!maxX = @val(%maxX)
close {%eqname}
%matname = "crits"
delete {%matname}
endif
endif
%infstring = ""
for !i=0 to !maxINF
if !i>0 then
endif
%xstring = ""
for !j=1 to !maxX
if !j>1 then
endif
'estimate equation
'capture criterion
endif
endif
endif
'compare criterion
!mincrit = !crit
!bestINF = !i
!bestX = !j
!ii=!i+2
!jj=!j+2
endif
You're estimating the equation:
Yet nowhere in your program have you defined what %arstring is, so that bit is meaningless.
kanonathena
Postby kanonathena » Thu Sep 02, 2010 5:54 am
After finding the model with the right lags for inflation and indicator x, I want to use recursive estimation to find all the forecast errors from one-step ahead static regression. Here is the code I modified from the rolling window thread based on a test model(.ls inf c inl(-1) ):
' get size of workfile
!length = @obsrange
' declare equation for estimation
equation eq1
%matname = "forecast errors"
table(!length-40,1) {%matname}
' move sample !step obs at a time
for !i = 0 to !length-40-1
' set sample to estimation period
smpl @first @first+40+!i
' estimate equation
equation eqtest.ls inf c inl(-1)
'calculate forecast error
smpl @first+40+!i+1 @first+40+!i+1
eqtest.forecast inffit
!error=@mean(inffit)- @first+40+!i+1 'calculate forecast error
'store forecast errors
{%matname}(!i,1)=!error
show {%matname}
Questions:
1. Regarding this part:
What is the function to extract the fitted value of inflation(I used @mean here since there is only one fitted value) and the corresponding actual value(@first+40+!i+1)?
Is there any other ways to calculate forecast error? I know these must be somewhere in the manual I just can't find it.
2. Regarding this part:
' estimate equation
How do I replace this with the model selected by AIC before:
equation {%eqname}.ls inf c {%bestINFstr} {%bestXstr}
How do I quote the result from a program before or must I nest it?
If there is any other problem you see please tell me.
tony
Postby tony » Mon Nov 01, 2010 7:29 am
if we make a MLE method to estimate the coefficients, rather than OLS, how to do the automatic arma selection?
pablete
Postby pablete » Tue Mar 08, 2011 4:35 am
Hey Gareth, I saw you mention that there is a limit on the ARMA terms, I assume there is a reason for that. I'm asking because I'm working with hourly data that are clearly autocorrelated up to 24 hours, I'm trying to stimate a model with AR terms AR(1) ... AR(24), Am I doing something essentially wrong? Or just impossible to do in EVIEWS?
Postby EViews Gareth » Tue Mar 08, 2011 9:00 am
Currently impossible to have all 24 AR terms.
I will point out though that your model would probably be quite unreasonable with all 24 AR terms.
peter.t
Postby peter.t » Sun Mar 27, 2011 7:08 am
Dear EViews Gareth,
I tried your program for an automatic ARMA selection and it worked.
Am I allowed to use your program for writing a paper, in which I have to estimate an ARMA model?
Of course, I would name you in the references section.
Thank you in advance for a reply!
Peter
